Unanswered Best Multi-tool?
Jun 10, 2018
310
85
United Kingdom
OneUp EDC tool system looks good, but I don’t know if my steerer is threaded or not on my Haibike Sduro Full Fat Six.
I was going to get a Topeak Mini 20 Pro 20 Function instead if it’s not. Is that the best one?
Mike Smith
300
209
Derby, UK
Have an old Topeak Alien Mini that does the job, although the Levo has a nifty multi tool stashed away on the frame.
The alien has a really good chain tool which is a very useful not checked whether the Pro20 has one.
Halcon
115
104
Texas
The One Up EDC requires a special tool (that they sell) to score threads into your steerer tube. If that is not a problem many people love it. Specialized sells their SWAT Conceal Carry MTB Tool that is held in the steerer tube at both ends and does not require you to thread anything but it cannot carry CO2 canisters and the tool itself may not have all the bits you require.
I have the SWAT tool and it works for me and I never forget it because it lives in the bike. Topeak does have the Ninja tools that attach with a water bottle.
Jun 10, 2018
310
85
United Kingdom
There's no best multitool
As a minimum try to choose one that covers every fastener on your bike and will split a chain.
There's no point having a fancy multitool if it won't re-tighten the bolt that has come loose.
Yeah well what I have been doing is carrying a toolkit in my pack, which I am tired of doing. If I can’t find a do it all Multi-tool, then maybe getting two diffferent ones will cover all the bases.
Tamas
483
503
Hungary/Bosnia and Herzegovina
I have the Topeak Mini 20 Pro for 4 years and I love it. It has everything I need on the road in a small light package.
Gary
Old Tartan Bollocks
10,496
10,702
the internet
One multitool should cover you. My point was more about finding one that covers everything without loads of extra pointless stuff.
Obvz you'll also need something to sort out punctures and inflate too
Mike Smith
300
209
Derby, UK
Topeak are good tools, the chain splitters are excellent seen a fair few other makes break!
I've had my alien for at least 10 years or so, and has all the essential fitments. I quite often use it whilst working on the bike in the garage instead of the main tools in the tool box!
The other thing I carry is a CO2 pump and a few tie wraps and spare tube, there was a thread a good while ago about what to carry. (y)
Mike Smith
300
209
Derby, UK
The original Alien was the daddy of tools all those years back!!
  • Like
Reactions: PGR
All Mountain Coaching
1,332
980
GB
I've had a crank brothers 17 for ages, no complaints. Don't think there is a 'best one'. In the winter the screw came off the end and it fell to pieces. They replaced it no questions, no receipt and sent 2x back
I have one of these - bit expensive but if you hunt about you can find them reasonably priced. Really like how you can increase the leverage by flipping the sleeve round, best multitool i have had.
F15
9,169
I carry the Topeak Hexus II and a Gerber Multiplier. Along with some zip ties and some gaffer tape wrapped around my mini pump, there's not much I can't fix.
Oh, and some spare brake pads, short lengths of chain, magic links, tyre wall patch, glue-less patches, a spare inner tube, and half a dozen paper towels! :eek:
But there are some things that can go wrong that nothing but component replacement or shed time will fix. :(
I also carry a small folding saw for trail obstructions, but that's a tool isn't it? :D
9,169
I have this one
Yeoman Turbo Folding Saw | J Parker Dutch Bulbs
This saw will go through 5" diameter tree branches like a knife through hot butter (only a slight exaggeration). I also use it as a very effective slasher to clear brambles, nettles and other trail barriers. It may also be an effective self defence weapon, but so far I've not needed it.
From experience the first thing I do is to replace the big screw that acts as the main hinge with another bolt that has a Nyloc nut to secure it. Because I also use the saw as a slashing tool, I lost a blade or two before I started making mods.
The other thing to change is the split pin that is the pivot for the blade locking mechanism. They are not robust enough for slashing duties, so I push it out and replace it with a galvanised nail that I saw off and then centre punch each end. If the locking mechanism fails, the blade can close on your fingers!
This all may see a bit of an arseache, but it doesn't take long and once done you only need to buy a new one when the blade goes blunt, and no trapped fingers! For less than £10 it is an absolute bargain and I don't travel off-piste without one. :)
  • Like
Reactions: Dax
Mad Mark
434
670
Burton on Trent
Do you have a trailer on the back of your bike ??
9,169
No trailer, just a Camelbak MULE. :love:
Containing all of the above, plus a Topeak digital pressure gauge, a small combination lock with one meter of steel cable, three chocolate covered flapjacks, 1.5 - 3 litres of water depending upon season, pain killers, car keys, £10 in an envelope, asthma inhaler. Depending upon weather forecast, extra layer and/or spare gloves. Doesn't feel like much and it feels like the right stuff to take. I have used all of it from time to time when the lack of it would have been very inconvenient. No room for a spare battery though!
549K
