Bent rotor hack
outerlimits
E*POWAH BOSS
1,241
1,575
Bent my rotor more than once on a single ride. So it was a bit special.
Rigged this up when I got home, so I could get it true again. Worked out better than expected.
As you can see it’s a small bolt that a ground to a point at the end. 2 nuts give it stability and are glued to the frame with a hot glue gun.
This gives a great guide when trueing the rotor as it can be screwed in and out.
The hot glue just snaps off the frame when finished. I suspect you could leave the nuts attached and carry the bolt in your kit for trail side repairs.
Could proberly use the same method to true a wheel with a bolt either side.
GrandPaBrogan
⚡ eGeezer ⚡
Oct 5, 2019
1,329
2,068
New Zealand
Nice rotors!
Is the rotor floating? I heard they can be noisy, but I'm still thinking I'd like to try something like that.
Left hand drive is so cool! ;)
outerlimits
E*POWAH BOSS
1,241
1,575
Nice rotors!
Thanks oh Grand One
Hope floaters for they are not noisey but expensive for those who like shine withholding the whine.
Centre drive is better and even coolera ! ?
outerlimits
E*POWAH BOSS
1,241
1,575
Sorry mate... it's either Zimmerframe's humour is rubbing off on me, or I've reached the age where I've started to regress into my childhood... :confused::sleep:
At the time I could not be bothered typing much more. ?‍♂️
In Australia floaters or floaturds are usually found in public swimming pools. Hence why I keep away from the yellow rivers ?‍♂️
Anyway... wtf were we talking about again..
That’s right Zimmer and his unassuming taste in humour and how it sticks like shit to a blanket. Dam it, I blame Zimmer anyway.
GrandPaBrogan
⚡ eGeezer ⚡
Oct 5, 2019
1,329
2,068
New Zealand
Back to topic... I'm really intrigued...
When my normal rotors go out of round, I usually get an adjustable spanner to clasp and gently nudge the spoke ever so slightly - the one (or the two) that's directly supporting the segment that's off. I never try to bend the outer ring itself.
What's the technique to straighten a floating rotor ring??
outerlimits
E*POWAH BOSS
1,241
1,575
I just jam a large Allen key in them to apply leverage to the outer ring or alloy body if needed. A shifting spammer also works.
I prefer the floating rotors as they are less prone to bending especially when they are 200-203mm. Much better than a big sheet of metal.
Gary
Old Tartan Bollocks
10,496
10,699
the internet
WTAF ???
You do realise all disc brakes come with a handy little set of pads spaced a mm or so from each side of the rotor that can be used as a trueing guide ?
outerlimits
E*POWAH BOSS
1,241
1,575
WTAF ???
WTAF ???
You do realise this is more accurate to dial in the final touches of trueing the rotor than the pads that can be hard to see the gap in right ?
Gary
Old Tartan Bollocks
10,496
10,699
the internet
it either rubs or it doesn't. We don't need our disc rotors trued to within microns
It won't stay true anyway... as you slowly seem to be finding out for yourself ;)
545K
