Beast of brenin on 500wh battery ?
Mteam
1,931
1,865
gone
should be easy in eco mode (or whatever the lightest level of assistance is), more difficult in full turbo.
Stretch40
326
133
Durham
We are going in June 3 of us have 500s the rest are 625 I'm slim but cos I'm 6ft 6 I'm still 85kgs plus I've done 20miles locally in hamsterley in mode 3and 4 sort of trail mode with 26% battery left but that's only with about 4-500 MTRS climbing not 1100 ? I'm thinking eco flat bits or downhill and trail uphill ?
Mteam
1,931
1,865
gone
what bike/motor is it?
1100 meters is about 3600 feet (I only work in feet...), I (85kg) can get about 30 miles and 6000 feet out of 625wh battery on the bosch gen4 using a mix of eco and off(on the downhills), so would have guessed that 3600 feet should be easy enough, but maybe not given your example above.
Stretch40
326
133
Durham
It's giant trance Yamaha motor well in feet I regularly do 20 miles and 1500ft climbing in setting 3-4 I've got 5 and have 20-30%left so I'm hoping in setting 2 eco plus I can get the 24miles and about 3-4000 ft climbing ?
Mteam
1,931
1,865
gone
There's a really boring bit on the beast which is just a fire road loop, which makes up 5 or so miles, you can skip it easily enough, and you're not missing any fun stuff, it's just a slog on a normal bike
I think it's only in there to make up the mileage numbers. It's obvious from looking at a map which bit it is because it goes out and comes back to nearly the same place.
571K
