Battery question Haibike
xotom125
Hello,
Im new to E biking and have just bought a Haibike 5.0 Allmtn, the battery is U/S.
What do you gain by buying a higher ampage output battery?
Better distance?
More power?
Etc
Thanks in advance
Max
33red
137
Quebec, Canada
Hello,
Better distance?
More power?
Etc
Thanks in advance
Max
Is it 500 Wh?
Do you have enough range?
What are your expectations?
xotom125
Is it 500 Wh?
Ive not ridden the bike yet, but I imagine that I would never be riding more than 15 miles at one time,
Which would all be off road.
500wh?
Its a yamaha motor set up other than that ive no idea. Not tuned but I will be fitting a tuning kit on it soon
Indigo
214
178
Brisbane, Australia
1 battery will easily take you 15 miles. Battery specs Wh (Watt hours) or Ah (Amp hours) are both a measure of storage capacity. Higher will get you better distance.
jerry
257
166
Belgium
Get your priorities straight - get to know the very basics of ebiking (including range, assistance levels, battery maintenance etc) instead of thinking of tuning the thing first!
xotom125
So the higher output on battery equates to longer life span between
each charge, and nothing else?
33red
137
Quebec, Canada
You have to do your part. This is pedal assist. Read it is easy to get used to a decent Ebike. If you like distance use your gears, do not allways use the maximum assist. I can ride over 4 hrs on my 500 Wh Yamaha.
xotom125
Thanks for all the replies,
Any advice on where to get the best deal on a battery?
555K
