Battery life when cold
rod9301
169
106
US
I have a500 ah battery, and i noticed that the range got smaller in the last couple of weeks
Temperature is lower, 45 degrees Fahrenheit instead of 85. Could this be the cause?
Tonybro
🦾 The Bionic Man 🦿
1,290
2,911
Lancashire
Generally, yes.
Almost all batteries suffer in low temperatures, camera batteries, AA batteries, etc. I notice it when cold (around freezing) that range suffers.
OleP
16
7
Roskilde, Denmark
Yes, and besides the battery being less efficient in the cold, many other factors will also contribute to reducing range, some more than others, but they all have a negative effect on range.
- Dense air in cold weather gives greater drag.
- You wear more clothes = larger surface for wind resistance.
- All lubricants in the driveline are stiffer = more loss.
- In winter, it typically blows more and more often, so you have more wind resistance.
- Wet roads provide greater rolling resistance.
The factors are not listed in order of priority, and there are probably more factors, but that's all I could think of right here and now.
552K
