Levo Gen 3 Battery charger
jjglass535
20
14
Tampa,Fl
Is there a way to open the levo turbo charger ? The cord has come out from the charger box and is hanging by the red and black wires. Or am I stuck buying a new charger, bike is out of warranty. Its a 2022 levo comp carbon
TheSnowShark
234
298
French-Alpes
I haven't taken mine apart yet, but I think it should open by removing the rubber pads underneath, in my opinion the screws are behind these pads..
Then and if possible, resolder the wires at the right places
jjglass535
20
14
Tampa,Fl
Thanks for the response. I think I’m going to try. I don’t need to solder anything as the wires are still good. It’s the rubber grommet that pulled out and it’s just hanging by the wires. Was going to tape it but as warm as the charger gets I think that might get real messy
TheSnowShark
234
298
French-Alpes
If it's just the rubber that came out, you should be able to put it back in place from the outside, or even use a little lubricant to help it slide into place.
549K
