Battery advice
DARKSTAR-TEK
uk
Hi , guys i'm creating a e-bike for a 3000 watt hub motor, pretty new to the game so just wanted to double check i'm buying the right battery cells... I believe there bootlegged samsung heres a image
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Well they are good value at that price. I don't know if bootleg means out the back of the factory, at that price off the back of a truck :) or a 'quality' replica. I'd go for 3 of these in series myself. I can't see the price but no doubt substantially more.
22.2V 32AH 6S8P 21700 SAMSUNG 40T INR21700-40T BATTERY PACK 15cm 14AWG XT90 with 15cm JST balance cable
6v-222v-32ah-6s8p-21700-samsung-40t-inr21700-40t-battery-pack-15cm-14awg-xt90-with-15cm-jst-balance-cable.jpg
DARKSTAR-TEK
uk
Thanks for the reply, i was wondering about the wattage I think it's 20 amp per hour...? however wanted to double check i wanted to build the battery case myself a right of passage if you will, I also intend to build a frame a enduro stealth bomber.
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Great! That's way more than a rite of passage. That's 20A maximum discharge current which is probably fine but of course will depend what hub motor & controller and at what voltage. For an effective & reliable 3kW I 'd suggest you check out Grintech - ebikes.ca - excellent products & resource especially their motor simulator. Input all your variables and it plots power, torque, speed, temperature etc.
Motor Simulator - Tools
DARKSTAR-TEK
uk
Great! That's way more than a rite of passage. That's 20A maximum discharge current which is probably fine but of course will depend what hub motor & controller and at what voltage. For an effective & reliable 3kW I 'd suggest you check out Grintech - bikes.ca - excellent products & resource especially their motor simulator. Input all your variables and it plots power, torque, speed, temperature etc.
cheers for the input as, i'm still in the research phase, will check them out for sure thanks for the pointer.
553K
