Levo Gen 2 base level fork swap to Lyrik
Cavi
376
123
California, usa
Be warned, if you do the base model fork swap to a Lyrik fork, make sure you get the adapter block to run the 200mm rotor, as it comes only set for 180mm rotor........ I am going to run 180mm rotor on the front till next week as there was none anywhere near me........
flash
1,050
986
Wamberal, NSW Australia
Did the base fork come without an adaptor? I thought most forks (except the new Zebb which is 200mm) came with 160 or 180 mounts as standard.
Gordon
fraatti
100
41
Finland
I just swapped base model turbo levo fsr fork rs 35 gold to rs lyrik ultimate. You could use existing brake adapters.
552K
