Are you sure you will not have a problem between chain and lower swing arm pivot if you perform your modification ? it's depend of Nb of teeth of your plate, but chain pass allready very close with OEM spider. i have installed protection and it is damaged.Definitely needs to be 5-7mm over.
Think I’ve found one and ordered it but apparently China in lockdown
OK, if you don't find it is not so difficult to change the hub (lot off time but not complicate)It’s miles away from the swing arm.
I recon the 52cl Bafang spider is designed for proper 148mm boost hubs. Mine are old school Hope pro 2 hubs with 148 boost adapters which means my Cassette sits further in the wheel.
Esta araña tiene menos desplazamiento que la original
