CaptKirk
Luna X2/ Bafang M600 standard controller replacement question, Has anyone successfully swapped out a motor controller on this model?? I have read where if this is done without a licensed dealer initializing the Controller to the motor, the result is a motor that will run in reverse. I also read that a hack involved bypassing some circuitry on the controller. My question is has anyone tried swapping any 2 leads on the 3 wire plug from the controller to the motor? This will reverse rotation on "ANY" 3 phase motor . Also what is the purpose of the drive shaft mounted magnet? Is there a "Hall effect" sensor to indicate rotation direction? Will flipping magnet over and regluing affect operation and motor direction? I was attempting to stockpile critical components to have on hand as needed but have found it may not be as easy as just buying the correct replacement part. Any suggestions?
