Hey guys,
having an issue with my ebike. It uses the EP8 motor. When the crank arms are slightly rotated there is a clunking noise, like something is catching. When pedalling on flat pavement, or climbing, only while in one of the top 3 highest gears the clunking sound is consistently audible. It does this whether the motor is engaged or not and even when the motor is turned off.
The crank arms are tight and the sound is without a doubt coming from within the motor.
it sounds similar to this guys problem posted here. I believe he meant to say happens when in high gears (easier gears) not low gears.
here’s a video demonstrating the issue when the cranks are slightly rotated:
Thank you!
Thank you!
