Anybody running a Fox coil on their Bullit?
Steveg56
8
8
California
I got an XL.
Sorry I wasn’t very clear. I would like to put a coil on my Bullit as well and was wondering how I would know what size to order. I do know the coils themselves are ordered based on body weight but don’t know what size I would need for the shock itself.
Gutch
453
241
South Carolina
Coil spring, 2.50-2.75" x whatever weight you need. This is for a fox dhx2. Your shock is a 230x62.5. Don’t forget to order the Fox lower bearing roller, for the lower mount. Or you could just use the fox lower hardware. Hope this helps.
Mtb247
17
14
84790
I'm running an MRP Hazzard on mine currently, and it is fantastic. MRP has been great to deal with. My Hazzard was originally a smaller shock made for my Levo. I sent it in and they overhauled it and changed the length, stroke and the tuning to work with my new SC Bullit.
AccousticBiker
12
yes both are m8x30. the stock rockshox comes with a bearing mount but santa cruz confirmed over email that you can either use the bushing or the fox bearing hardware.
R3Z3N
82
64
California
The Fox roller bearing is definitely nice, but I feel it is cumbersome to work with, and I believe needs to be removed if swapping springs? Another alternative is the Real World Cycling needle bearing kit
Also, if using the Fox roller bearing, the tool is quite $$$
I have both, the RWC on my Kenevo SL and Fox Bearing on my SC Hightower. For those on air, the RWC is the clear winner for servicing/removing air can.
545K
