Hitorogoshi
I can see the battery lights flashing inside there when charging. Just concerned water and other crap will go in there near the connection block?
I have Meta Power TR 2021 and no plug just the hole as you say.
However its houses also the battery charge LED.
To see the state of charging or if its completed the LED flashes green or is solid when charged.
If you have a bung in it, how to you know when the bike is charged? Also if you have to remove the bung to see the LED what do you do if you've a bottle cage - mine has a hole in cage to see LED.
Seems a faff to have to remove bottle cage to remove or fit bung to see if bikes charging or charged.
Not that I'm aware of.You've got no issues with water ingress there?
