Thanks for the advice, I’ve just got to be brave and drop the motor and have a look at what I’m dealing with. CheersCorrect. The only visible portion is from the lever to the front of the head tube.
It’s critical to get the seat height correct before you cut the outer cable to length otherwise the cable gets squashed/kinked inside the seat tube.
Install the dropper with the cable attached, set the required height the pull back most of the slack then cut it to length at the bar remote. You may have to take it all out again to feed the inner cable through but it’s worth doing. Leave enough slack for slight seat height adjustment, this can be pushed into the down tube without causing a kink.
