My local shop had one that they wanted to move, and I found myself unable to resist the deal. The bike is well spec'd, weighs under 50lbs, and uses a Shimano E8000 with a standard 500 Wh battery. This bike is for my son, and soon we will all be riding together
Knowing very little myself, about bike dimensions and how they effect performance, it should be interesting to contrast this bike to the others in the garage. It has shorter chain stays, steeper seat post, and steeper steering angle than the others.
Anybody have one? Make it a conversation.
edit to add day one info.
Some Observations:
The KHS is the lightest of the bikes I can weigh. On my super duper and honest Pelouze produce scale:
It's the easiest to ride a wheelie on.
The rear derailleur cable routing is not great, leading to a heavy feel at the shift lever. I cut the zip-ties holding the cable at the bottom of the down tube where the cable comes out of the frame, and the shifting feel became lighter. I called KHS and asked for an updated routing, if one existed, or a service bulletin? We will see if I get a call back.
The bike build is otherwise very nice.
Some Observations:
- KHS 6555+ Size Large = 50 lbs
- BMC SpeedFox AMP 3 Size Medium =52 lbs
- Giant Trance E+ 1 Pro Size Medium = 54.5 lbs
