Any alternatives to the Rockrider e-st900?
TheWho
33
9
Hey, I'm new from the UK. I'm looking to get my first emtb to help me get back outside as part of a slow recovery from a long-term illness. Beginner mtber. Because of that I'm looking to get a bike that can do nearly all the work for me to start with and I can extend the trips later if/as I recovery. I'm trying to avoid anything that's too heavy in case the bike has a problem.
I'm mainly in a hilly and wet area, and will probably be 80% on paths, fields, bog, mud.
Budget £1,800.
I'm looking at the Rockrider e-st900, as it's got good reviews. It seems to have been downgraded at some point from a 90Nm motor to a 70Nm though? I can't see much else in terms for alternatives.
Are there any other good alternatives to the Rockrider I should be considering for under £1,800?
Brian VT USA
92
67
VT, USA
You might be better off with a hub drive and a throttle until you get back into shape? With a mid-drive you need to pedal all the time.
TheWho
33
9
Thanks, I hadn't realised that. I'll have to see if I can find anything with a hub drive.
Planemo
605
706
Essex UK
You need to pedal all the time with a hub drive as well (if legal). Unless you go for a legislated throttle but theres only 1 or 2 companies in the UK that sell them.
What will be the primary use of the bike? Road or trail?
TheWho
33
9
Trail.
Planemo
605
706
Essex UK
Without going secondhand I'm not sure you'll do much better than the Rockrider for that money tbh. You'll want a mid drive for hills anyway, and at least the bike will cope with trails/mild off road stuff OK. If it were me I would take the Decathlon bike over the Halfords one too.
Maybe someone else will chime in if theres any better options up to £1800 (y)
TheWho
33
9
Okay, so having a good look around at second hand I could get a Cube reaction hybrid pro 625 2021 for about £1,300. Is it worth the risk of second hand to get that better bike? Will it still have good support/power as a hybrid?
E-MAD MALC
390
214
EAST SUSSEX
There's quite a few on the forum with the 900
Good value for the money, I've had mine 2 years over time upgraded parts, one of the first things I did was swap the tyres out for faster rolling
552K
