Bike / Product Year: 2020
Manufacturer: Vitus
Model: E-Escarpe VRS
Asking Price:
Location Halifax (West Yorkshire)
Description FOR SALE, SIZE MEDIUM priced at what i think is a decent price with a big chunk knocked off new list price (but open to sensible offers).
Bought the bike new back in may. As you can see in the pictures the bike has only done 345 mile and 34 hours of riding and won't be doing anymore until the sale. The bike runs and performs faultless and it's only down to personal circumstances that forces the sale. Anyone that is put off by the thought of mullet bike, don't be, i really like it and think it gives the best of both worlds and would defo get another mullet for my next bike (whenever that may be). The grip the rear 2.8 tyre gives is fantastic and will get you up anything.
As shown in the pictures there is a slight stone chip on the downtube (no dent just a chip) and also the scuff on the chainstay, this was only done in my error as was tackling a rocky loose track uphill and the bike just had too much power and flipped over the top of me and due to the weight couldn't control it so it scuffed against a rock. Just mention this so you know it hasn't had a crash.
Comes with the Ergon grips also that i swapped out instead of the Vitus ones that will also come with the bike.
Would prefer pick up but could be willing to travel within 100 mile round trip from my house in Halifax.
See spec below and any questions drop me a message, cheers.
FRAME eEscarpe 29"/27.5" 140mm travel full suspension eMTB frame Boost, 6061 Alloy, Shimano STEPS compatible | REAR RIM DT SWISS H1700 Spline 35 eMTB specific, 27.5", 35mm inner rim width |
FORKS Fox Float 36 Performance eBike+ 29" 140mm Grip Damper, Kabolt 110, 44mm Offset | FRONT HUB DT SWISS H1700 Spline eMTB specific, Boost 110x15mm, 6-bolt Disc |
SHOCK Fox Float DPS Performance 3 Position Dial, Trunnion, Evol LV air spring, 205mm x 57.5mm, 0.8 Spacer, custom tune | REAR HUB DT SWISS H1700 Spline eMTB specific. Boost 148x12mm, 6-bolt Disc, Shimano 12spd MICROSPLINE steel freehub |
CHAINSET SHIMANO E8000 34T 165mm CHAIN LINE 53MM | SPOKES DT SWISS |
BOTTOM BRACKET Shimano E8000 N/A | FRONT TYRE MAXXIS ASSEGAI 29"x2.5"WT, 3C MaxxTerra/EXO+/TR |
REAR TYRE MAXXIS MINNION DHR2 27.5"x2.8", 3C MaxxTerra/EXO+/TR | |
REAR DERAILLEUR Shimano XT 12 speed RD-M8100, SGS 12-SPEED, TOP NORMAL, SHADOW PLUS | FRONT BRAKE SRAM Guide RE 200mm Centerline Rotor |
SHIFTERS Shimano XT 12 speed M8100, 12-SPEED RAPIDFIRE PLUS | REAR BRAKESRAM Guide RE 200mm Centerline Rotor |
CASSETTE Shimano SLX 12 speed 10-51T CS-M7100-12, HYPERGLIDE+, 10-12-14-16-18-21-24-28-33-39-45-51T | HANDLEBARS Nukeproof Horizon "AL7050, 25mm Rise, Back 9deg, up 6deg, Bar Diameter 31.8mm Width - S780mm, M780mm, L800mm, XL800mm" |
CHAIN Shimano SLX 12 speed N/A | STEM Nukeproof Neutron |
MOTOR BATTERY Shimano E8010 500wh N/A | HEADSET ACROS ZS 44mm/56mm |
MOTOR COMPUTER Shimano E8000 N/A | GRIPS VITUS Tapered, single alloy clamp, sticky rubber |
MOTOR SHIFTER Shimano E7000 N/A | SADDLE WTB Volt 142 COMP 0 |
MOTOR DRIVE UNIT Shimano E8000 DRIVE UNIT COVER, SM-DUE80-A | SEATPOST Brand X Ascend 31.6mm, Left hand remote lever, S100mm, M125mm, L150mm, XL170mm |
FRONT RIM DT SWISS H1700 Spline 30 eMTB specific, 29", 30mm inner rim width | SEAT CLAMP VITUS 34.9mm seat clap with quick release lever |
