dhmeridarider
Hey guys, had this Merida for a couple of years now, did have the 'ahem' badass freeze mod fitted, finally got it serviced, they took the mod off, they said it could/will damage the bike, happy to run without it anyway for now.
But is there any way the Alfine hub can not show the correct gear on the speedo display?
eg 4th Feels like 1st and 8th feels like 4th.
Like I'm pedalling like crazy in 8th, and only just hitting 20kph, never gets to the 25kph cutoff stage.
From memory when I first got the bike I could achieve 25kph with no issues then the motor cuts out as it is legally supposed to. With the mod fitted could achieve 40kph in 8th gear (have a second speedo), then you would be pedalling like crazy to go any quicker.
It beeps as you change gear in manual, and you can hear it changing.
Have connected PCE02 and all components are the on the latest firmware.
There is an slider for Auto Adjustment from -13 to +13, not even sure what this does?
I'll take it back to the shop for another look, just wanted to know if anyone else has had any issues?
Cheers.
(Not technically a eMTB sorry peeps, hope thats ok on these forums)
Cheers.
