Hi guys.
Please can the hivemind help.
My E-Sommet VRS E8000 has developed an issue. No fault code comes up though.
When riding the speedo on the display keeps jumping up to 2 or 3 times the correct speed for couple of secs, which corresponds to the motor disconnecting. Presumably it thinks its going over the restriction.
Magnet is correctly aligned and I've visually checked the speed sensor and connection into the motor. Also the cadence on the display does not jump about like the speed does & always shows the correct RPM.
If its just a faulty speed sensor I'll prob just replace it rather than deal with CRC warranty dept again - 10 weeks to get a replacement for an obviously faulty battery! But as the cadence is correct I'm unsure.
