RickBullotta
Has anyone integrated a bike light to their Rise yet?
Yup. I have a display but not clear where to route/connect the wiring.Should be the same as integrating a light into any other shimano motor - might need to run a display though as IIRC that’s how you run it on and off
The wiring connects into a port on the motor under the cover on LHS
if you go to the Shimano forum there is a Sticky thread which has the manual pdf in it and should show you how.
You will need to enable it in firmware too. By default there is no power going to the ports. There are detailed steps shared on "Orbea Rise" group on Facebook.Thanks - I'm just not sure if I have any room in the internal routing tubes on the Rise though. Will take a look. Appreciate the tip!
