Unanswered 35mm stem to 50mm
Cseven
61
42
Seattle
I converted my Kenevo expert from a 27.5 to a mullet setup. This shortened my reach by about 40mm. I put a 35mm stem on it and was wondering if changing from 35 to 50 would drastically change how my Mtb rides? If so in what ways?
Gary
Old Tartan Bollocks
10,496
10,702
the internet
a 29" wheel only raises the front axle by 19-20mm so to shorten your bikes reach by as much as 40mm you'd have had to fit a much longer axle to crown fork as well. And in doing so you'd have slackened the bike's H/A considerably and raised the bike's bar height and BB height.
ie. in which case you've already drastically changed how it rides.
i wouldn't be worrying about the difference in handling between a 35mm stem and 50mm stem. 50mm stems steer fine on slack bikes. But generally when you up the travel (and fork axle to crown length) on a bike in order to retain a lot of it's handling traits you'd also ideally want to lower the stem/bars by 2/3 to 3/4 of the increase axle to crown length. and in your case at least another 15mm lower again to offset the 19-20mm increase in front axle height.
Whether your bike even came with enough spacers below the stem to lower the bars sufficiently I wouldn'y know. But if not a set of lower rise bars is probably your best solution.
552K
