35mm rise handlebar
Lee c
259
203
Uk
Hi all looking for a 35mm rise handlebar to fit a 35mm stem, 780 width
kuyawil
California
Checkout the Deity Highside 35 handlebars. They come in a 50mm and 80mm rise. They come in 800mm width only but can be cut down. I was using the OneUp Carbon bars but they only came in a 35mm rise and needed higher rise. So far, I’ve been pretty happy. Good luck with your search.
Lee c
259
203
Uk
Thanks mate that’s a great shout I think I’m looking for a ride around 40mm but not entirely sure, going to have to try a few I think, thanks for the suggestion mate your bike looks wicked
kombos
252
311
Arizona
I ran the 50mm Diety bars on my Levo and liked them (Now on my Surron).
I later swapped stem and went with the 35mm One Up carbons. Found they were a bit less harsh in the rocks.
Julie_X1
133
114
Canada
Another vote for the One Up in the 35mm rise version. They only come in a 800mm length but of course you can cut them down to 780.
I am impressed with how they compliant they are. At first I was worried about going from a 31.8mm to 35mm clamp size, as my hands are quite sensitive to vibrations, but they absorb vibrations even better than the 31.8mm carbon bars on my other bikes.
Lee c
259
203
Uk
Thanks guys I’ve seen nothing but good things about the one up bars think it may be time to put my hand in my pocket 😂
9,040
Did any of you find an e-bike version with a crease in the bar ends to allow wires to go under the grips and into the bar? Or did you reroute the wires around the outside?
Julie_X1
133
114
Canada
OneUp now has a e-bike bar that is compatible with certain systems. Edited to add: “Our Carbon E-Bar has internal routing for Shimano STEPS switch units and Bosch LED Remote.”
That’s the one I got, even though it’s not compatible with my e-bike. They’re actually very slightly (5%) even more compliant than their normal carbon bar.
Lee c
259
203
Uk
RaceFace makes them in Alloy or Carbon. Raceface Atlas.
Thanks mate I had read that the race face bars gave quite a stiff ride on the hands ? Have you experienced this yourself ?
Shjay
835
491
Kent
Running the One-up 35mm carbon ebar on the Rise & Joystick Analog 30mm rise on the Mega, I like the sweep on both bars. Think I ride them more rolled forward than others do
543K
