The Flying Dutchman
The post mount setup was a bit tricky and I needed to experiment with a few different mounts / washers until I found an arrangement where the waves of the rotor cleared the caliper body but didn't leave overhanging pads surface. I couldn't find a 223mm rotor adapter online so if you're planning to run a similar setup be prepared for a bit of trial and error.
I didn't notice a bit of juddering from the brakes but I'll resurface the pads and rotors then re-bed. I also have another 223mm which I'll put on the back tonight and hopefully get it fit with the parts I have.
More to come!
