Levo Gen 2 220mm rotors on hope v4?
Cavi
376
123
California, usa
soo this past weekend I did the Flume trail in Tahoe, and the downhill side is currently very sandy and you pick up quite a bit of speed so I was using quite a bit of brakes and was worried i would boil over my Hope V4 that are on 200mm stock rotors.
I am currently running a Lyrik select so to tun the 200mm stock I am running 20mm spacers so I figured that this Hope adapter that adds 43mm is the correct one. I ordered the mangura rotor as the Hope rotor is out of stock, and the Mangura seems sturdier than the SRAM
Did I order the right parts?
554K
