Tubby G
❤️🔥 Hot Stuff ❤️🔥
Hi Forum
I’m having an issue fitting a 203mm Magura rotor to my partner’s Rise with FOX 34 forks
The adapter I bought is the incorrect size. I purchased the Magura 180-203mm QM44 adapter
My Rise has the FOX 36 forks with 203mm rotors, and uses the Shimano SM-MA-F180P/P2 adapter (fitted in Orbea factory)
when holding the two adapters side by side, they’re exactly the same size, and the new Magura adapter fits my FOX 36 forks absolutely fine
However, I have now noticed the post mounts on the FOX 34 forks are in a slightly different position to the FOX 36 mounts
So question is, has anyone converted their 180mm rotors to 203mm rotors on their FOX 34 fork and if so what adapter did you use ? Thanks
