For Sale (BIKE) 2023 trek powerfly 7 large: 2500
jaggysnake
166
109
uk
Bike / Product Year: 2023
Manufacturer: trek
Model: powerfly 7
Size large
Asking Price: 2500
Location uk north west
Description bizarrely just found out can not list ebikes on ebay or batteries as well whats that about
“in very near new condition , only used on road and light canal tracks , 695 miles”
bought oct 23 from mtb monster
selling due to lack of use
complete with charger and both keys and documentation
totally stock with mucoff valves and peatys sealant
can deliver locally or further for 60p a mile
only had road and light canal path use
payment via bacs or cash , bike will not be released until full payment recieved
The Powerfly 7 is an electric mountain bike built with quality trail components, a high-performance Bosch e-MTB system and a durable aluminium frame featuring our new Removable Integrated Battery (RIB) system that fully encases the battery. RockShox air suspension, a 1x12 Shimano drivetrain and a dropper post make this e-MTB the ideal choice for those who want a boost on the climbs so they can get rad on the way down.
Key Features
  • Bosch Performance CX motor: Perfect for tackling the climbs
  • RockShox 35 Gold Fork: Keeps you in control on the descents
  • Shimano SLX 1x12 Drivetrain: Simplicity combined with a wide gear ratios
Full Specifications
  • Frame: Alpha Platinum Aluminum, Removable Integrated Battery (RIB), tapered head tube, Control Freak internal routing, Motor Armor, Boost148, 12mm thru axle
  • Fork: RockShox 35 Gold RL, DebonAir spring, Motion Control damper, lockout, tapered steerer, 44 mm offset, oversized crown for eMTB, Boost110, 15 mm Maxle Stealth, 120 mm travel
  • Motor: Bosch Performance CX, magnesium motor body, 250 watt, 85 Nm, 15.5mph or 25km/h max assist
  • Battery: Bosch PowerTube 625
  • Controller: Bosch Kiox
  • Number of Gears: 12
  • Gear Shifters: Shimano SLX 7100, 12 speed
  • Chainset: E*thirteen E*spec
  • Chainrings: 34T
  • Rear Cassette: Shimano SLX 7100, 10-51, 12 speed
  • Chain: Shimano SLX 7100, 12 speed
  • Front Derailleur: N/A
  • Rear Derailleur: Shimano Deore XT 8100
  • Pedals: VP-536 nylon platform
  • Rims: Bontrager Line 30, Tubeless Ready, 32-hole double-walled
  • Front Hub: Bontrager Boost110
  • Rear Hub: Bontrager sealed bearing alloy axle, Boost148
  • Tyres: Bontrager XR3 Team issue, 29x2.40? (15.5: 27.5x2.3?)
  • Brakes: Shimano 4-piston hydrauilc disc, MT6100 lever, MT6120 caliper
  • Handlebars: Bontrager alloy, 31.8mm, 15mm rise, 720mm width
  • Headset: FSA IS-2, 1-1/8" top, 1.5" bottom
  • Stem: Bontrager alloy, 31.8mm, Blendr compatible, 7 degree, 70mm length
  • Saddle: Bontrager Commuter Comp, 165mm width
  • Seatpost: TranzX JD-YSP18, 130mm travel, internal routing, 31.6 mm, 425 mm length
  • Accessories: N/A
  • Weight: M - 22.91 kg / 50.5 lbs (with tubes)
PXL_20241114_122034105.jpg PXL_20241114_122049405.jpg PXL_20241114_122100696.jpg PXL_20241114_122103038.jpg PXL_20241114_122107273.jpg PXL_20241114_122113292.jpg PXL_20241114_122116288.jpg PXL_20241114_122122574.jpg PXL_20241114_122125957.jpg
574K
