For Sale (PARTS) 2023 Fox 36 Grip 27.5 Ebike forks. 225: Berkshire
Weeksy
646
714
Newbury(ish)
Bike / Product Year: 2023
Manufacturer Fox
Model 36 Grip 27.5 Ebike forks.
Asking Price 225
Location Berkshire
Description Fox 36 Float Grip Performance Forks - 27.5" - Gloss Black / 160mm / Tapered / 15 x 110mm / 27.5"
Barely used, i think they've been used 3 times, but we've sold the bike they were fitted to. Bought from Merlin Cycles in Sept 2023.
Steerer measures 188mm
Everything present and correct, no marks, no issues.
Fox 36 Float Performance GRIP Boost MTB Forks - 27.5"
The undisputed all-mountain champion Fox 36 receives an update in the form of a new crown with updated design and engineering for more steer tube overlap improving durability and maintaining stiffness while dropping 20 grams.
FIT GRIP
Inspired from moto, the GRIP damper uses Fox's FIT sealed cartridge technology combined with a coil-sprung, independent floating piston. GRIP allows excess oil to purge through specially designed ports at the top of the damper to maintain consistent damping and increase durability.
NEW Crown
Lighter by 20 grams, while increasing steerer-tube overlap at the CSU, the new crown design improves durability while our engineering maintains stiffness and drops weight.
Axle
Kabolt, a lightweight bolt-on floating axle to shave grams and increase torsional stiffness via a sleeveless, single-sided pinch bolt design.
Float EVOL
Optimizes small bump sensitivity by increasing negative air spring volume. Its linear spring curve delivers plushness off the top, extra mid-stroke support, and more tunable bottom-out progression.
Specification
Wheel Size: 27.5"
Travel: 160mm
Offset: 44mm
Damper: FIT GRIP (3 Positions)
Max Tyre Size: 27.5 x 2.80"
Steertube: 1.5 Tapered
Axle Options: Boost 15x110
Uppertube Finish: Black Annodised
575K
