For Sale (BIKE) 2022 Trek Powerfly 5 M: 2800
Nutcake
Kidderminster
Bike / Product Year: 2022
Manufacturer: Trek
Model: Powerfly 5
Size M
Asking Price: 2800
Location Kidderminster
Description Hi,
This is a great E-Bike with so upgrades compared with the standard 2022 bike.
The bike is in fully working order and is ready to ride.
Notable Items for your search:
Bosch Performance CX Motor - 75NM - 250 Watt - <400 Miles on the Clock
Dropper Post - 170mm
Shimano 4-Piston Hydraulic Disc
All specs for the bike is below but if you have any questions, please let me know.
Thank you
Frame: Alpha Platinum Aluminium, Removable Integrated Battery (RIB), tapered head tube, Control Freak internal routing, Motor Armor, Boost148, 12mm thru axle
Fork: RockShox Recon Silver RL, Solo Air spring, Motion Control damper, lockout, tapered steerer, 42 mm offset, Boost110, Maxle Stealth, 120 mm travel
Motor: Bosch Performance CX, magnesium motor body, 250 watt, 75 Nm, 15.5mph or 25km/h max assist
Battery: Bosch PowerTube 625
Controller: Bosch Purion
Number of Gears: 12
Gear Shifters: Shimano Deore 6100, 12 speed
Chainset: Ethirteen Espec 165mm length
Chainrings: 34T
Rear Cassette: Shimano Deore 6100, 10-51, 12 speed
Chain: Shimano Deore 6100, 12 speed
Front Derailleur: N/A
Rear Derailleur: Shimano Deore 6100
Pedals: VP-536 nylon platform
Rims: Bontrager Kovee, Tubeless Ready, 32-hole double-walled
Front Hub: Bontrager Boost110
Rear Hub: Bontrager sealed bearing alloy axle, Boost148
Front Tyre: Bontrager XR3, 29x2.30"
Rear Tyre: Bontrager XR3, 29x2.30"
Brakes: Shimano 4-piston hydraulic disc, MT4100 lever, MT420 caliper
Handlebars: Bontrager alloy, 31.8mm, 15mm rise, 750mm width
Headset: FSA IS-2, 1-1/8" top, 1.5" bottom
Stem: Bontrager alloy, 31.8mm, Blendr compatible, 7 degree, 70mm length
Saddle: Bontrager Commuter Comp, 165mm width
Seatpost: Bontrager alloy, 31.6mm, 12mm offset, 400mm length
575K
