For Sale (BIKE) 2021 Whyte E160S Large: £3300
JGardner92
Shrewsbury
Bike / Product Year: 2021
Manufacturer: Whyte
Model: E160S
Size Large
Asking Price: £3600
Location Shrewsbury
Description Hi,
For sale is my E160S. Has done less than 200 miles from new and was invisiframed on purchase so is in fantastic condition. It's just not being used so a shame to not see it being ridden.
Collection from Shrewsbury. Any questions, please let me know
Spec as below:
BIKE SPECIFIC SPECIFICATION
MOTORBosch Performance Line CX (Gen 4). 85 Nm max Torque, 250 W nominal power, 2.79 kg 4 Power settings including progressive eMTB mode which automatically adjusts the supportBATTERYBosch 625 Wh internal PowerTube. Reaches full charge in 5 hours with supplied 4A Compact Charger, 80% charge from 0 in 2.5 hoursDISPLAYBosch Purion
SPECIFICATION
COLOURMatt Burnt Orange with Black & EarthCASSETTESRAM PG-1210 Eagle, 11-50, 12 Speed
FRAME6061 Alloy, Hydro Formed T6 Aluminium, Multi Butted, Custom Drawn, Tapered Headtube, Internal Cable Routing for Dropper Post and 12mm X 148mm Boost DropoutsCHAINSRAM GX Eagle, 12 Speed
FORKRockShox ZEB 27.5", 160mm Travel, 44mm Offset, DebonAir, Charger R Damper, Fast Black Coating, Tapered Steerer, 110mm x 15mm Boost, Maxle UltimateCRANKSETSRAM EX1, 165mm, ISIS with X-SYNC 2, Direct Mount 34T for Bosch Gen 4, Black
REAR SHOCKRockShox Deluxe Select + RT, DebonAir, Fast Black Coating, Adjustable Rebound, 2 position compression adjustmentBOTTOM BRACKETN/A
HEADSETFSA No. 57E Orbit ZS, 1 1/2" Lower and 1 1/8" Upper Sealed Cartridge BearingsSEATPOSTWhyte drop.it Adjust, 30.9mm, XS/S 120-150mm Travel, M/L 140-170mm Travel, XL 170-200mm Travel, Paddle Remote Lever
REAR HUBAlloy, e-bike specific, Double Sealed Cartridge Bearings, 12mm x 148mm Boost Through Axle, 32 HoleSADDLEWhyte Custom, Triple Panel Design
FRONT HUBAlloy, Double Sealed Cartridge Bearings, 15mm x 110mm Boost Through Axle, 31mm Torque Caps, 32 HoleHANDLEBARWhyte Custom 6061 Alloy, 30mm Rise, 35mm Bar Bore, 780mm Wide
SPOKESDT Swiss Champion 2.0mm, Black Stainless, Brass NipplesSTEMWhyte Enduro Stem, 35mm Bar Bore, 35mm Extension
RIMSWTB HTZ i30 TCS 2.0 System, Asymmetric, Sleeved Joint, Super Tough Construction, Tubeless Ready, 32 HoleGRIPSWhyte Lock-on V Grip
TYREWTB Verdict TCS System 27.5" X 2.5" Light/High Grip, Tri-Tec triple compound High Grip, Lightweight Casing with Slash Guard, Front, WTB Verdict TCS System 27.5" X 2.5" Tough/High Grip, Tri-Tec triple compound, Fast Rolling, Enduro Casing, RearBRAKES FRONTSRAM Guide RE, 4 Pot with Sintered Metal Pads, 220mm Rotor
SHIFT LEVERSSRAM GX-E, Single Click, MMX, 12 SpeedBRAKES REARSRAM Guide RE, 4 Pot with Sintered Metal Pads, 200mm Rotor
FRONT MECHN/ABRAKE LEVERSSRAM Guide RE, MMX
REAR MECHSRAM GX Eagle, 12 SpeedPEDALS
578K
