Sold 2021 Trek Rail 7 M: £3000
supertom44
Great Haywood UK
Bike / Product Year: 2021
Manufacturer: Trek
Model: Rail 7
Size M
Asking Price: £3000
Location Stafford - UK
Description This bike has been absolutely amazing, loved every second of riding it.
In decent condition with some minor cosmetic marks as can be expected.
Purchased from Evans on 08/03/2021.
Spec is stock apart from:
Grips - DMR Brendog Death Grip Red Thick
Pedals - DMR V12 Flat Pedals Black One Size
Saddle - Ergon SM E-Mountain Sport Men's Saddle
Happy to answer any questions and veiwings are welcomed.
This is for collection only from Stafford area.
Many thanks.
Tom
Spec taken from website:
Specifications
Product Trek Rail 7 E-Bike
Model Year 2021
Riding Type
Enduro / All-Mountain
Rider
Unisex
Sizes and Geometry
SM (high, low)
MD (high, low)
LG (high, low)
XL (high, low)
Wheel Size
29"
E-Bike Class
Class 1: Pedal Assist (Pedelecs)
Motor Bosch Performance CX, magnesium motor body, 250W, 75 Nm torque
Battery Bosch PowerTube 625, integrated, removable
Battery Capacity 625 Wh
Display/Remote Bosch Purion
Modes Turbo, Sport/eMTB, Tour, Eco, Walk Assist
Max Speed with Assist
20 mph (32 km/h)
Frame Material
Aluminum
Frame Material Details Alpha Platinum Aluminum, magnesium rocker link, Motor Armor, molded chainstay protection
Rear Travel
150mm
Rear Shock RockShox Deluxe Select+, 230mm x 57.5mm
Fork RockShox Yari RC, DebonAir spring, Motion Control RC damper, e-MTB optimized, 42mm offset
Fork Travel 160mm
Head Tube Diameter Tapered, 1.125" top, 1.5" bottom
Headset Trek Knock Block
Handlebar Bontrager Rhythm Comp, alloy, 31.8mm clamp diameter, 15mm rise, 780mm width
Stem Bontrager Rhythm Comp, 31.8mm bar clamp, Knock Block compatible, 0° rise, 50mm length
Grips Bontrager XR Trail Comp, nylon lock-on
Brakes Shimano, 4-piston, Shimano RT76 6-bolt 203mm rotors
Brake Levers Shimano
Drivetrain
1x
Shifters Shimano SLX M7100, 12-speed
Front Derailleur None
Rear Derailleur Shimano Deore XT M8100, 12-speed, long cage
Chainguide
Cranks e*thirteen e*spec Plus, 165mm length
Chainrings e*thirteen e*spec Plus, 34 tooth
Pedals VP-536 nylon platform
Chain Shimano SLX M7100, 12-speed
Cassette Shimano SLX M7100, 12-speed, 10-51 tooth
Rims Bontrager Line Comp 30, tubeless ready
Hubs Bontrager Line Comp 30 wheelset, sealed bearing, 6-bolt rotor mounts, 15x110mm Boost front, 12x148mm Boost rear with MICRO SPLINE driver
Spokes Bontrager Line Comp 30 wheelset
Tires Bontrager XR5 Team Issue, tubeless ready, Inner Strength sidewall, aramid bead, 120 TPI, 29" x 2.6"
Saddle Bontrager Arvada, steel rails, 138mm width
Seatpost TranzX JD-YSP18 dropper
Drop: 100mm (SM), 130mm (MD/LG/XL)
Seatpost Diameter 31.6mm
Seatpost Clamp Single bolt, 36.4mm
Rear Dropout / Hub Dimensions 12x148mm Boost
Max. Tire Size 29" x 2.6"
Bottle Cage Mounts One inside front triangle
Colors Dnister Black/Rage Red, Miami Green/Nautical Navy
Warranty Lifetime frame and wheels; 2 years Trek/Bontrager parts, suspension linkage components, and paint/decals
Weight
52 lb 0.1 oz (23,590 g)
Miscellaneous Removable Integrated Battery (RIB) system
ABP (Active Braking Pivot) suspension system
Geometry adjustable via Mino Link flip chip in rear rocker link pivot
Straight Shot frame design with Knock Block steerer stop
Control Freak internal cable routing
Weight given for MD frame with tubes
Includes Bosch standard 4A (100-240V) charger
577K
