For Sale (BIKE) 2021 Specialized Turbo Levo S-Works S5: 5000
Jamo
66
31
Fife
Bike / Product Year: 2021
Manufacturer: Specialized
Model: Turbo Levo S-Works
Size S5
Asking Price: 5000
Location Dunfermline
Description S5
Full spec:
Levo S-Works S5 Carbon Frame
Fox Float X2 210x55
Fox 38 Grip 2 160mm
Specialized Roval SL carbon wheels
Shimano XTR Brakes
Magura 203mm rotors
Specialized S works carbon bars 35mm x 780mm
Deity Copperhead stem 35mm length
Rockshox reverb AXS 170mm
Sram XX1 AXS shifter
Sram GX AXS rear derailleur
Sram XX1 eagle 12spd chain (black)
Sram XX1 eagle cassette
Praxis carbon 160mm cranks
ODI grips have not seen much use
Conti Argotal tyres
Standard S-Works spec except brakes have been changed to Shimano XTR.
Stem has been shortened to 35mm to bring in the reach but is Deity Copperhead same as original spec.
Original xx1 rear mech replaced with GX axs.
New main cable fitted between motor and battery, Oct 24 (£290) so this is good as new. Charging port door also upgraded at same time. New rotors and pads in Oct 24 as well.
Brakes have been freshly bled and fork oil changed.
I have removed the original blue sticker decals from wheels but have a fresh set of decals from slik graphics for the nee owner to fit (or you can leave the original stealth specialized graphics if prefer)
I will consider selling the frameset only if that’s of interest.
Original owner, will provide all paperwork, receipt, etc
07764 969277
578K
