Sold 2021 Specialized Turbo Levo Comp: 6500
ScottWest
126
76
Oregon
Bike / Product Year: 2021
Manufacturer: Specialized
Model: Turbo Levo Comp
Asking Price: 6500
Location Portland, Oregon, USA
Description 2021 Specialized Turbo Levo Comp.
Large
Beautiful Condition
288 Miles
13 Charge Cycles. 100% Battery Health
Warranty: 16 Months remaining (September 2022) on Electric Components
Feel free to message for details...
Technical Specifications
FRAMESET
Frame: Specialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, dropper post routing, 148mm spacing, fully sealed cartridge bearings,
150mm of travel
SUSPENSION
Rear Shock: FOX Float DPS Performance, 3-position adjustment, 52.5x210mm, Rx Trail Tune
Fork: Fox Float 36 Rhythm, Grip damper, 160mm, Sweep-Adj, 51mm rake, Kabolt Axle
Battery: Specialized M2-700, integrated battery w/rock guard, 700Wh
Charger: Custom charger, 42V4A w/ Rosenberger plug
UI/Remote: Specialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
Motor: Specialized Turbo Full Power System 2.1 Motor
Chainring: Praxis, 32T, steel
Chain: Shimano XTR, 12-speed (UPGRADE)
Crankset: Praxis forged M30, custom offset
Cassette: Shimano SLX, CS-M7100, 12-speed, 10-51t
Rear Derailleur: Shimano SLX M7100, SGS, 12-speed
Shift Levers: Shimano SLX, M7100, 12spd
Front Brake: Shimano SLX M7120, 4-piston caliper, hydraulic disc, 203mm
Rear Brake: Shimano SLX M7120, 4-piston caliper, hydraulic disc, 203mm
WHEELS
Tubless (UPGRADE)
Rear Hub: Shimano MT510-B, Centerlock 28h, 12x148 Boost, Microspline
Rear Tire: Eliminator, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.3"
Rims: Specialized 29, hookless alloy, 30mm inner width, tubeless ready
Front Tire: Butcher, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
Front Hub: Shimano MT400-B, Centerlock 28h, 15x110 Boost
COCKPIT
Handlebars: Specialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm width
SeatPost: One Up Dropper 150mm with Fox Remote (UPGRADE)
Grips: Specialized Trail Grips
Stem: Alloy Trail Stem, 35mm bar bore
Saddle: Bridge Comp, Hollow Cr-mo rails, 155/143mm
Seat Binder: Specialized bolt-type, alloy, 38.6mm
Pedals: Crank Brothers Stamp 1
576K
