Sold 2021 Specialized Levo Comp Medium: SOLD
Rickmonty
West Sussex
Bike / Product Year: 2021
Manufacturer: Specialized
Model: Levo Comp
Size Medium
Asking Price: £-
Location West Sussex, UK
Description Have been debating this for a while but it may be time to part with my 2021 Levo Comp in size Medium. Bought brand new in March 2021 from Je James Cycles, Warranty is transferrable to new owner. Battery has been charged only 16 times since new - very, very good condition. Only noticeable mark is some heel rub on the left crank arm sticker (I ride left foot forward). The bike has been helitaped from new and some of the edges have started to lift but I have left it on to keep some protection.
Superb bike, plenty of range and more power than you would ever need! This is the updated motor with a manufacturer date of 3rd September 2020. Comes with all documents, charger, case and folders etc.
Specification as follows;
FrameSpecialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, dropper post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
Rear ShockFOX Float DPS Performance, 3-position adjustment, 52.5x210mm, Rx Trail Tune
ForkFox Float 36 Rhythm, Grip damper, 160mm, Sweep-Adj, 51mm rake, Kabolt Axle
StemAlloy Trail Stem, 35mm bar bore
HandlebarsSpecialized, 6061 alloy, 6-degree upsweep, 8-degree backsweep, 30mm rise, 780mm width
TapeSpecialized Trail Grips
SaddleFizik Taiga S-alloy rail
Front BrakeShimano SLX M7120, 4-piston caliper, hydraulic disc, 203mm
Rear BrakeShimano SLX M7120, 4-piston caliper, hydraulic disc, 203mm
Shift LeversShimano SLX, M7100, 12spd
CassetteShimano SLX, CS-M7100, 12-speed, 10-51t
Rear DerailleurShimano SLX M7100, SGS, 12-speed
ChainShimano SLX, M7100, 12-speed
CranksetPraxis forged M30, custom offset
ChainringsPraxis, 32T, steel
Front HubShimano MT400-B, Centerlock 28h, 15x110 Boost
RimsSpecialized 29, hookless alloy, 30mm inner width, tubeless ready
Rear HubShimano MT510-B, Centerlock 28h, 12x148 Boost, Microspline
SpokesDT Swiss Industry
Front TireButcher, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
Rear TireEliminator, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.3"
Inner TubesN/A - set up tubeless
Seat BinderSpecialized bolt-type, alloy, 38.6mm
SeatPostX-Fusion Manic, infinite adjustable, two-bolt head, bottom mount cable routing, remote SRL LE lever, 34.9mm, S: 125mm, M/L: 150mm, XL: 170mm
MotorSpecialized Turbo Full Power System 2.1 Motor
UI/RemoteSpecialized TCU, 10-LED State of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, w/Handlebar remote
BatterySpecialized M2-700, integrated battery w/rock guard, 700Wh
ChargerCustom charger, 42V4A w/ Rosenberger plug
Wiring HarnessCustom Specialized harness
Looking for £-, collection preferred or may be able to meet within a reasonable distance. Sorry, unable to post and would much rather people see and test the bike in person.
Any questions let me know.
576K
