For Sale (BIKE) 2020 Specialized Turbo Levo Large - £2000
Banktramp
327
315
West Midlands
Selling my Specialized turbo levo as I broke my ankle six months ago and change of circumstances means it’s just not getting used.
Just under 360km, I’ve owned since new and has mainly been local trail with a few uplifts and always washed and maintained after every ride.
It had a new motor, speed sensor and power harness done under warranty in 2021 at the concept store.
Any questions please ask, more than happy to answer whatever you need.
Spec below:
Frame
Specialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel.
Rear Shock
RockShox Deluxe RT w/ custom air valve, 150mm of travel.
Fork
RockShox Sektor RL, 29" Boost™, 150mm of travel.
Rear Derailleur
SRAM NX, 11-speed
Shifters
SRAM S700, single-click lever.
Chain rings
32T, custom steel
Cassette
SRAM PG-1130, 11-speed, 11-42t
Chain
KMC X11ET, 11-speed w/ Missing Link™
Front Brake
SRAM CODE R, hydraulic disc, 4-Piston Caliper, 200mm
Rear Brake
SRAM CODE Hydraulic disc, 4-Piston Caliper, 200mm
Handlebars
NukeProof Horizon 780mm, 31.8mm clamp
Stem
NukeProof Horizon, 3D-forged alloy, 4-bolt.
Grips
Ritchey soft grip
Rims
Roval Traverse 29, hookless alloy, 30mm inner width, tubeless ready
Spokes
DT Swiss Industry
Front Tyre
Magic Mary 29x2.6”
Rear Tyre
Eddie Current 29x2.6"
Seatpost
34.9mm mechanical dropper, NukeProof Horizon Seat Clamp
Motor
Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
Battery
Turbo M2-500, fully integrated w/ rock guard, 500Wh.
Crankset
Praxis, 2D cold-forged alloy, custom offset, 165m
Pedals
NukeProof Horizon Clipless
Mudguard
ProGaurd Full Front/Rear
Few age related marks but overall in good condition for its age, the tubeless sealant could do with changing and has a slow leak from the valve on the rear wheel, I do have a new set of Muc off valves just not got around to fitting them.
Also included is original charger.
£2000
Located in West Midlands
View attachment IMG_0281.jpeg View attachment IMG_0282.jpeg View attachment IMG_0284.jpeg View attachment IMG_0285.jpeg View attachment IMG_0287.jpeg View attachment IMG_0289.jpeg
577K
