The 2020 PF5 comes with 500 battery. Anyone confirm if it can take a 625 battery later?
Q qwertycube New Member Apr 29, 2020 52 17 Scottish Highlands May 9, 2020 #1 The 2020 PF5 comes with 500 battery. Anyone confirm if it can take a 625 battery later?
Doomanic 🛠️Wrecker🛠️ Patreon Founding Member Jan 21, 2018 8,968 10,954 UK May 9, 2020 #2 I’m pretty sure it can’t. A simple way to tell; where the battery is bolted to the battery cover, is there a spacer that effectively makes the battery longer?
Q qwertycube New Member Apr 29, 2020 52 17 Scottish Highlands May 9, 2020 Thread starter #3 Does anyone have PF5 who can confirm if 500 battery has a spacer fitted? that would allow a longer 625 battery to fit? Thanks.
W WilkyWay Active member Dec 26, 2019 120 104 Durham UK May 10, 2020 #4 If the PF5 has Gen 4 motor The 625 will fit. I have a Rail with 625 battery and the wife’s PF5 has a 500, both batteries work in both bikes. Both with Gen4 motors.
Doomanic 🛠️Wrecker🛠️ Patreon Founding Member Jan 21, 2018 8,968 10,954 UK May 10, 2020 #5 How does the 625 fit in the PF? It’s significantly longer.
W WilkyWay Active member Dec 26, 2019 120 104 Durham UK May 10, 2020 #6 They’re exactly the same size. The battery at the bottom of the picture above is the 500, with the plastic spacer. Top is the 625 with no spacer.
Q qwertycube New Member Apr 29, 2020 52 17 Scottish Highlands May 10, 2020 Thread starter #7 Thanks for replies. I’ve since found a reply to same question on Trek’s own technical Q&A forum. Yes, 2020 PF5 can take either battery?
Pascal Funk Active member Apr 2, 2020 108 384 France May 10, 2020 #8 Can we know the weights of the two ? Why the covers are not the same length ? Thank's.....
W WilkyWay Active member Dec 26, 2019 120 104 Durham UK May 10, 2020 #9 They are. It’s just the perspective of the picture.
