lamerecycles
Bike / Product Year: 2020
Manufacturer: Haibike
Model: XDuro AllMtn 2.0
Size Medium
Asking Price: $4800
Location Minneapolis, MN
Description Haibike's 2020 AllMtn 2.0 model opens up an enormous range of uses: With a mix of 160mm travel up front and 150mm at the rear as well as 27.5" wheels with plus tyres, you can make your way, with confidence, over every terrain and enjoy first-class performance even on challenging descents. The powerful Yamaha PW-X2 motor powers you up every hill for a smooth, natural feel to the ride.
Dirty tires due to some demo rides, otherwise new - only 27 miles on the odometer.
Specifications:
ENGINE: Yamaha, PW-X2, 250 W, 80 Nm, 25 km/h
DISPLAY: Yamaha, Side Switch, 1.7" LCD, 7 functions
BATTERY: Yamaha, Lithium Ion, 500 Wh
FRAME: Aluminium 6061, Thru-axle M12 (1.75) x 148mm, Disc brake Post Mount, Travel= 150 mm
FORK: RockShox, Yari RC, Air, Travel= 160 mm, Aluschaft 1 1/8 - 1 1/2'''' tapered, 15 x 110mm thru-axle Boost
DAMPER: RockShox, Deluxe Select Plus, Air, 65.0 mm
CRANK ARM: Haibike Components, The Crank ++, Aluminium
BRAKE (FRONT): Shimano, MT520, 203 mm, 4-piston disc brake
BRAKE (REAR): Shimano, MT520, 180 mm, 4-piston disc brake
TUBE: Presta valve
RIMS: Rodi, Tryp 35, with eyelets, hollow rim, Aluminium
CLAMPING RING: Internal hexagon, 34.9 mm
REAR DERAILLEUR: Sram, NX Eagle
SHIFT LEVER: Sram, NX Eagle, Trigger switch, 12 speed
BOTTOM BRACKET: integrated in the motor
SPROCKET: Sram, Eagle PG1210, 11 - 50 teeth
CHAIN: Sram, NX Eagle
CHAINRING: Sram, 38 teeth
CHAIN GUIDE: Haibike aluminium/Nylon directmount
BRAKE LEVER: Shimano, MT501, Aluminium
BRAKE DISC (FRONT): Shimano, RT64 203
BRAKE DISC (REAR): Shimano, RT64 180
TIRES: Maxxis, Minion DHF, 71-584, 27.5" x 2.80"
FRONT WHEEL HUB: Haibike Components, TheHub ++, 6-bolt standard
REAR WHEEL HUB: Haibike Components, 6-bolt standard
SPOKES: Sapim, Leader, black
HANDLEBAR: Haibike Components, TheBar ++, 780 mm
GRIPS: Haibike, MTB grips
STEM: Haibike Components, TheStem 2, A-head, Bar bore: 31.8 mm
HEADSET: Feimin, A-Head Tapered, Aluminium, cartridge bearing
SADDLE: Haibike Components, TheSaddle
SEAT POST: XLC, AllMtn, Remote, Telescope, 31.6 mm
PEDALS: Freeridepedal, Aluminium, with Reflector
WEIGHT (KG): 23.6 kg or 52.03 lbs
PERMITTED TOTAL WEIGHT: 120.0 kg or 265 lbs
TIRE (REAR): Maxxis, Minion DHR II , 71-584, 27.5" x 2.80"
RIM (REAR): Rodi, Tryp 35, with eyelets, hollow rim, Aluminium
