For Sale (BIKE) 2019 Specialized Turbo Levo FSR Comp (Alloy) L: £2100
Timwillows
21
Portsmouth
Bike / Product Year: 2019
Manufacturer: Specialized
Model: Turbo Levo FSR Comp (Alloy)
Size L
Asking Price: £2300
Location Portsmouth, Hampshire, UK
Description Specialized Turbo Levo (Alloy) Comp, 2019 model, Size L
Bought new from Berkshire Turbo in May 2019, so got a couple of months left on the four year warranty, original receipts available. Odometer 5900km / 134 charge cycles.
500Wh battery showing 100% health, motor running well and quiet. Running latest firmware. Suspension serviced in autumn 2022 by TFTuned, no issues with the units identified. New cassette, chain and chainring (34t) fitted in December. Brakes, tyres (tubeless, Muck-off sealant) all good with reasonable life on them. Fitted with stainless steel engine guard. Original charger.
Does have some standard light scratches on the frame and several stone chips, though most appear to be in the clear protective plastic than into the paintwork itself, couple of scratches on the wheel rims, but otherwise true and dent free. Abrasion on left fork stanchion, caused by a stone that got caught, was in place before last service (TFT verdict was to keep using it) and is not causing any performance issues or oil leaks, so purely cosmetic, touched up for cosmetic reasons. Overall bike is in very good condition.
Really need to deep clean to get those pictures looking their best!
Collection only, cash or bank transfer.
SPECIFICATION – changes from original shown
FRAMESpecialized M5 Premium Aluminum, 29 Trail Geometry, integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
FORKRockShox Revelation Charger RC, 29” Boostâ„¢, 150mm of travel
REAR SHOCKRockShox Deluxe RT w/ custom air valve, 150mm of travel
FRONT HUBSpecialized, sealed cartridge bearings, 15x110mm thru-axle, 28h
REAR HUBSpecialized, sealed cartridge bearings, 12x148mm thru-axle, 28h
SPOKESDT Swiss Industry
RIMSRoval Traverse 29, hookless alloy, 30mm inner width, tubeless ready
INNER TUBESStandard, Presta valve Tubeless, Muck-Off sealant
FRONT TYREButcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6”
REAR TYREButcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6”
CRANKSETPraxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRINGS32T, custom steel 34T Praxis
SHIFT LEVERSSRAM S700, single-click lever
REAR DERAILLEURSRAM GX, long cage, 11-speed
CASSETTESRAM PG-1130, 11-speed, 11-42t, Shimano M7000
CHAINKMC X11ET, 11-speed w/ Missing Linkâ„¢ Shimano M7000
FRONT BRAKESRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKESRAM Guide RE, 4-piston caliper, hydraulic disc, 200mm
HANDLEBARSSpecialized Trail, 6061 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
GRIPSSpecialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEMSpecialized Trail, 3D-forged alloy, 4-bolt, 6-degree rise
SADDLEBody Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
SEATPOSTX-Fusion Manic, 34.9mm, 125mm of travel (Small), 150mm of travel (M/XL)
SEAT BINDERAlloy, 38.6mm
MOTORSpecialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/REMOTESpecialized TCU, 10-LED state of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, handlebar remote with walk-assist
BATTERYTurbo M2-500, fully integrated w/ rock guard, 500Wh
CHARGERCustom charger, 42V4A w/ Rosenberger plug
WIRING HARNESSCustom Specialized wiring harness
PEDALSSpecialized Dirt Nukeproof Neutron EVO
576K
