Sold 2019 Specialized Turbo Levo Expert Medium: £5390
dogpoododger
uk
Bike / Product Year: 2019
Manufacturer: Specialized
Model: Turbo Levo Expert Medium
Asking Price: £5390
Location Southend on Sea, Essex
Description For sale, 2019 Specialized Turbo Levo Expert Medium Frame £5390 ono. Originally bought from Specialized Concept Store Chelmsford, October 2019, all receipts are available. It's had light usage by my wife and son (780 miles), neither of them progressed further than the blue trails. There's signs of wear consistent with use but still looks really good. It's still under warranty, 6 months on the battery, 30 months on the motor, lifetime on the frame. The battery has only had 20 of the warranted recharge cycles of 300. I've put on a new chain and cassette. The tyres are good and everything is working well. I'm based in Southend on Sea in Essex. It's a great riding, powerful bike but I'm old school and it's just not getting used enough.
If you're interested please contact me via emtbforums or call Jeremy on 07915 455038, thanks
Below is the spec from Specialized
FRAME FACT 9m Carbon w/ M5 alloy rear triangle, 29 Trail Geometry, Integrated down tube battery, enclosed internal cable, Command Post routing, 148mm spacing, fully sealed cartridge bearings, 150mm of travel
FORK RockShox Pike RC29, 150mm of travel
REAR SHOCK RockShox Deluxe RT3 w/ custom valve, 150mm of travel
FRONT HUB Specialized, sealed cartridge bearings, 15x110mm spacing, 28h
REAR HUB DT Swiss 360, 3-pawl design, SRAM XD driver body, 12mm thru-axle, 148mm spacing, 28h
SPOKES DT Swiss Revolution
RIMS Roval Traverse 29, hookless alloy, 29mm inner width, tubeless ready, 28h
INNER TUBES Standard, Presta valve
FRONT TYRE Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
REAR TYRE Butcher, GRID casing, GRIPTON® compound, 2Bliss Ready, 29x2.6"
CRANKSET Praxis, 2D cold-forged alloy, custom offset, 165mm
CHAINRINGS 32T, custom steel
SHIFT LEVERS SRAM S700, single-click lever
REAR DERAILLEUR SRAM X1, 11-speed
CASSETTE SRAM XG-1175, 11-speed, 10-42t
CHAIN KMC X11ET, 11-speed w/ Missing Linkâ„¢
FRONT BRAKE SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
REAR BRAKE SRAM Code R, 4-piston caliper, hydraulic disc, 200mm
HANDLEBARS Specialized Trail, 7050 alloy, 8-degree backsweep, 6-degree upsweep, 27mm rise, 780mm, 31.8mm clamp
GRIPS Specialized Sip Grip, half-waffle, S/M: regular thickness, L/XL: XL thickness
STEM Specialized Trail, forged alloy, 4-bolt, 6-degree, S/M 40mm / L/XL 50mm
SADDLE Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
SEATPOST Specialized Command Post 34.9mm, 130mm of travel (Size: Small), 160mm of travel (Sizes: M/XL)
SEAT BINDER Alloy, 38.6mm
MOTOR Specialized 2.1, custom Rx Trail-tuned motor, 250W nominal
UI/REMOTE Specialized TCU, 10-LED state of charge, 3-LED Ride Mode display, ANT+/Bluetooth®, handlebar remote with walk-assist
BATTERY Turbo M2-700, fully integrated w/ rock guard, 700 Wh
CHARGER Custom charger, 42V4A w/ Rosenberger plug
WIRING HARNESS Custom Specialized wiring harness
574K
