For Sale (BIKE) 2019 CUBE STEREO 160SL AL 500 LARGE: £2675.00 ono
Oldcreaky
50
48
Bristol
Bike / Product Year: 2019
Manufacturer: CUBE
Model: STEREO 160SL AL 500
Size LARGE
Asking Price: £2675.00
Location Bristol
Description I have had this bike from new and comes with all original paperwork,as you can see it has done 3941 miles and has not had a hard off road life.
Forks are Fox 36 170mm travel Shock Fox DPX2 160mm travel Shimano XT drive chain
Shimano XT 4 pot brakes.
Full spec is on the Cube website.
Saddle is By Fabric. Bars are Nukeproof Neutron V2 alloy riser bars, dropper lever is Wolf tooth.
A carbon bash plate is fitted along with the winter mudguards. Grips are Ergon C3.
The motor is quiet and does everything it is supposed to do, battery still retains charge as it has always done. Gear change is excellent even under load. The chain has it lot of life left as you can see from the photo, the rest of the drive train is excellent as well.
Pedals are DMR vaults.
Overall condition is excellent with only a relatively few marks mostly on the fork leg stickers. It is also Datataged but there is a fee to register a new keeper.
There are three small issues the dropper post sticks at the bottom of its stroke sometimes,
The front brake is noisy on full bite but not every time and when i was cleaning i found one strand of the gear change cable was broken so should be changed for reliability's sake.
Include with the bike are a new set of Shimano brake pads(rear pads low). Original seat and bars alongwith set of Race Face cut down bars. A set of RRP enduro mudguards for the summer, a new Bosch speed sensor cable. Only brought because i had the fault code appear only to discover on inspection that the plug had detached itself inside the motor.Spare inner tube for safety's sake not needed as running tubeless. Spare pins for the pedals.
Please contact if any more info required.
Open to sensible offers.
577K
