Other 2018 turbo Levo battery fault - 3 red flashing LEDs + beeping
Dmitriysx
Hi all, new to this group. I’m having an issue with my gen1 Levo battery. 3 LEDs flash red with beeping, when I try powering it on. This happens for no longer than 20 seconds, then shuts down. Won’t charge. Can briefly connect to mission control. Just had motor refurbed, but happens whether plugged in or not. Anyone had this? Thanks in advance.
salko
1,305
895
SLO
There was recall on some gen1 batteries, check if yours is included, if it is, you might get a new one...
Dmitriysx
Thanks, I’ll have a look; assuming it’s somewhere on the specialized website i need to check this?
umaxumix
Indonesia
Hi all, i also new to this group. I’m having an issue with my gen1 Levo battery. The battery as well as Dmitrysx has... 3 LEDs flash red with beeping, when I try powering it on. This happens for no longer than 20 seconds, then shuts down. Won’t charge also.. if the gen1 Levo battery mostly like that?? Anyone had this? Thanks in advance.
571K
