FlowDough
A graph posted by Specialized which was verified by independent lab shows how power varies with cadence in some of the most popular motors.
The most revealing part of the graph to me was the efficiency of the Specialized 2.1 motor at higher pedaling cadences. While the other motors start to flatten out and become less efficient above 100 rpm, the 2.1 actually continues to increase in efficiency. Essentially, the faster you spin the pedals on the 2.1 the more efficient the motor is, which increases your range. What did Specialized change to make the motor more efficient at high rpm's? Looking at the graph, I couldn't help but wonder at what rpm's the efficiency starts to dip on the 2.1, or if it ever does. Does the efficiency continue to increase infinitely?
Spinning at 120 rpm might seem somewhat tiring, but if you train for it on a spin bike or fixed gear bike it's not hard to do for extended periods of time in an easy gear.
Projecting the graph trends into infinity, imagine the efficiency of the 2.1 at a cadence of 250 rpm:
Clipless pedals increase your pedaling efficiency by allowing you to apply torque more evenly throughout the pedal cadence, which helps motor efficiency. I've noticed my 2.1 seems more efficient and smoother when I'm focusing on the upstroke while pedaling, without putting much conscious effort into the downstroke. Have any others riders also felt this or experimented with higher cadences on the 2.1 and noticed if it extended the battery range?
