MrPeaski
Decided to do a lever bleed on the bike today after it has been hanging up for a while (it pulls close to the bar and is a bit spongy).
Used the same Comma LHM mineral oil that I've used before without problem.
Started with the back, removed the wheel and took out the pads. Bleed block in and connected everything up and purged the red Shimano oil out of the system (didn't want to mix them) as I've done many times before. closed the bleed nipple, nice firm lever.
Re-fitted the bleed screw into the lever, bleed block out, pads and wheel back in and gave the lever a couple of pulls to re-set the pads.
Thing is now when the lever returns, its definitely a bit slower than it was (and the untouched front) and the very last part has a tiny jolt as if it gets stuck for second.
No probs, I thought, it obviously doesn't like this oil, so I'll just get the proper stuff. Thing is I can't seem to find any of the larger 1L bottles anywhere, only the piddling little 100ml ones which are silly money for the size.
Any body know where I can get a 1L bottle from?
Brakes are Shimano XT 8120's
