Levo Gen 2 '19 Levo, motor given up, still replaceable?
miPbiP
755
805
Surrey Hills.
hey all long time no see hope you're doing good.
my '19 Levo has been going well until the motor disintegrated a few weeks ago. well out of warranty now obvs and shop I bought out from is no longer a Spesh dealer.
where to start on a replacement? everything else on the bike is ok apart from rear wheel bearings a bit flaky, not high mileage for its age.
tyvm.
(motor symptoms - bike freewheels forwards with motor turned off and on, I rode it home under my own steam no problem. won't freewheel backwards, strong resistance after say 50cm of movement. motor makes a whirring noise for a second on first couple of pedal strokes then no noise.
something as simple as the drive belt has broken or disengaged?).
thanks.
anyway bit of a lazy post, will do some searching.
am based in SE England (Surrey) if any dealers/repairers nearby!
James_C
530
269
Kent, UK
I think you are describing a sprag clutch bearing failure, which I've had 4 of :)
Similar to above would also recommend ebike motor centre, and if keeping the bike I'd suggest the "brose upgrade service" which includes that and various other bits. Also 1yr warranty. £180 ish. You are close enough to do a "while you wait" visit which is what I did but need to book it in a few weeks in advance.
A new motor is about £850 from a dealer. Ebike motor centre also sell them cheaper than that though.
552K
