Other 175mm Fox Transfer in S3 Kenevo 2023
ebikerider
706
484
It will physically fit but the main factor to consider is your inside leg length. You need to work out insertion depth of each and total height and go from there.
drumfrodo
15
11
Norway
Based on my measurements, this should work fine. I was trying to find out if a 200mm Fox Transfer would fit my S4 Kenevo, but figured it would be just a tad too long to insert fully. But 175 shouldn't be an issue, so presumably not on an S3 either. Since the Transfer is either 30.9 or 31.6mm in diameter, it shouldn't have issues with hitting the nipples on the suspension pivot bolts. However, these can be filed away as well should it present a problem.
553K
