155mm cranks what a difference
Gary
Old Tartan Bollocks
10,496
10,717
the internet
Bobo approves ;)
B1rdie
918
1,133
Brazil
Do you feel any difference on the balance front/rear and traction control when pedaling off the saddle on steep climbs?
B1rdie
918
1,133
Brazil
Felt a tad strange at first but took all of two minutes to adjust. Had the motor fail after the first climb at the forest of dean a couple of weeks back, pedalled the rest of the ride without motor assist and had no problem.
Thanks!
This would be the downside of shorter cranks for me, I can cope with a few pedal kicks but as I usually ride slowly, balance is key for me.
The other downside I could guess is on fast turns when the outside foot would rather be as far from the BB as possible. But this is not a problem for the same reason.
Gary
Old Tartan Bollocks
10,496
10,717
the internet
The biggest downside will be if you also ride regular bikes. When switching back you'll take with you your newly formed bad habits but won't have the same 20mm safety net to make up for them.
being 20mm higher when stood weighting a dropped outer pedal while cornering won't make a huge difference to cornering stability
B1rdie
918
1,133
Brazil
If I rode like Amauri Pieron that difference would matter for sure.
But I have to agree that changing bikes would feel strange for muscle memory.
LUCKYMULLEN
81
69
Falkirk
Just out of curiosity, did you have to raise the height of your seatpost to counter the shorter crank arm length when pedalling seated?
576K
