Answered 11 spd. Cassette where you can by individual sprockets?
Hasse Birkmose
93
42
Denmark
On my third cassette in 5 months. Commuting is wearing the 11 teeth ring out in no time.
Is there a brand where bying a new 11t Sprocket is an option?
Thanks in advance ;-)
slippery pete
163
241
What brand are you on? Shimano? I've got lots of cassettes where I've worn out the large sprockets and not worn the 11t from analogue biking. I could probably find you 1 or 2.
It may be the wear problem is not purely a wear problem. On smaller sprockets you can definitely have issues with chain wrap being insufficient. Maybe some fine adjustment of the b screw can get you a few more kms as long as it doesn't screw up the large sprocket clearance.
Pylie1
38
20
Depending on what brand you’re running and cassette type, you can buy individual smaller cogs/gears. I’m not sure if I’m allowed to link bike shops in this particular forum, so I won’t ? Although, if you do a quick search on google with ‘11 tooth cog replacement ’ you should be able to find what you’re looking for?
Gary
Old Tartan Bollocks
10,496
10,702
the internet
Your LBS can order you in 11 and 13t shimano sprockets. Any Shimano dealer can. BTW They're not all that cheap.
a cheaper alternative in the long run would be to run a larger chainring (if possible) and learn to spin faster reducing the amount of time you spend in the 11t
I have 2 wheelsets, 1 for commuting (with slicks fitted) and the other for off-road and changed to 10 speed shimano gearing so I could run an 11-25 road cassette on the commuting wheelset and a 10speed mtb cassette on the other.
I also have 2 sram chains (1 specifically for each cassette) with quicklinks so it's not massively more time consuming when swapping wheels.
the close ratios of the 11-25 means I use the sprockets far more evenly on the road
the sprocket @Mikerb linked to is 10 speed not 11. (spacing is different). you need CS-M8000
552K
