yt decoy
  1. wenna
    E-Tube Ride app di2 control
    So I was trying to find a better use for the extra button that is on the di2 shifter. On my YT Decoy Core 5 with EP801 and the 12-speed di2 the button was set up to switch between gear shifting modes. But I never switch between those modes (always run freeshift) so I set out to find a better...
  2. Strive77
    E8000 rattle.
    Hey guys. Just wondering if anyone has had or has a rattle on the E8000? I had my motor replaced on YT Decoy and this one seems to rattle on the downhills. It’s not slap as I’ve had the chain off and tried and everything seems nice and tight. You can hear it if you drop the bike on the rear tire...
  3. maaalex
    New member intro - YT Decoy Uncaged ;)
    hey everyone, new here! About me, I was born in 1986 and have always ridden everything with two wheels. Childhood and youth BMX, mainly flat and a little street, currently trial with an Inspired 4play, downhill with a custom Scott Voltage and more and more with my Decoy Uncaged 9. The latter is...
  4. E
    It's totally dead !
    Hi, Any help would be much appreciated. My Decoy Pro 29er has totally died. I used it for 10 mins on Friday. It had a full battery showing a range of 45 miles. No problems on a quick 5 minute test ride. I went to go for a long ride on Saturday afternoon and the bike wouldn't turn on. Nothing...
  5. B
    Sizing on YT Decoy
    Hello all, I am new to this forums and family new to EMTB. I just ordered a Large YT Decoy Core 3 which has a least 3-4 months to be delivered. I looked at the sizing chart and compared it to my Santa Cruz Bronson which seemed comparable. I am 5'10.5 and 210. My inseam is 30 inches and I...
  6. Darian
    Shimano rejected warranty
    Hi guys, advice please.... Story goes....i have sent my YT Decoy back because of faulty bearings. But Shimano refusees to change the motor because i have mounted aftermarket lamp and cabel of Lightmove se 150 (has shimano compatibility and all kind of certifications and rewards). Also when i...
  7. A
    Shimano 11 speed Di2 to 12 speed AXS?
    Hi chaps. I have a 2019 pro race decoy. It has Di2. I want to look at changing to 12 speed AXS, anyone on here done this and what should I expect to have to change- free hub and everything?
    Could go out to the sea. 2 more weeks and it's fully frozen.
    New goggles and winter gloves = winter ice riding fun.
    Latest run. No spikes + high tire pressure = slippery time. Much easier for the four-legged friend.
    The perfect weather for a ride. Or the perfect ride for the weather?
    Went biking with a friend/student of mine and he caught this on his phone as we were moving. Turned into a decent avatar/profile picture.
    This is a wallpaper I made using GIMP. One of many.
  14. contigo
    Anyone running a Mezzer + Decoy - Does the reverse arch contact the frame?
    Or does the knock block do its job? This is for the Decoy mullet. thx!
  15. N
    Decoy delivered damaged - advice please
    My Decoy Pro 29 finally turned up after quite a long wait considering it was in stock. But the excitement quickly vanished when I found this. Seems the mech hanger has rotated and dug into the seat stay, splitting the carbon. There was no damage to box or packaging, so can only assume it...
  16. N
    YT Decoy delivered damaged advice
    My Decoy Pro 29 finally turned up today after quite a long wait considering it was in stock. But the excitement quickly vanished when I found this. Seems the mech hanger has rotated and dug into the seat stay, splitting the carbon. There was no damage to box or packaging, so can only assume...
  17. N
    YT Decoy Base/Pro 29 size advice
    Can anyone give some sizing advice on the Decoy Pro 29? I’m 5’8” ish (173.5cm) so would need a Large based on YT’s size guide. But looking at the medium geometry compared to my medium Bronson, which i’m super comfortable on, the decoy reach is 20mm longer, standovers the same give or take a mm...
  18. N
    Decoy Pro 29 size advice
    Can anyone give some sizing advice on the Decoy Pro 29? I’m 5’8” ish (173.5cm) and would need a Large based on YT’s size guide. But looking at the medium geometry compared to my medium Bronson, which i’m super comfortable on, the decoy reach is 20mm longer, stand overs the same give or take a...
  19. D
    Consumer Rights - Where do I stand in getting a refund on my Decoy?
    Hi All, as many other have shared on these threads, I'm having a nightmare with my Decoy, I have no faith in the long term reliability of the system and I no longer wish to own the bike. I'm really struggling with my YT experience and was wondering if anyone else here has been through similar...
  20. Subzilla
    Di2 shifting problem
    Hi, I’m having real shifting problems with my decoy, it worked quite well up to my chain exploding due to a poor connection I’d made. Everything looks ok, bit I cannot get it to shift correctly on the last 2 cogs 10 down to 9 and back up again. I have tried a new chain, cleaned the mech, cleaned...
