Hi guys,
I’ve got a 23 gen 3 Turbo Levo that’s going to need a drivetrain swap soon.
I am thinking about just doing the whole thing at once to get away from having to replace other related components down the road.
Does anybody have any good recommendations on which and where to get a complete...
Hello
I was wondering what would you go and why between specialized turbo levo comp alloy and canyon strive on underdog.
Both are same price at ~5000€.
I have heard good things about spec customer service but on canyon they are bit mixed. Motors are good but im still bit unsure about brose...
So I’ve been researching my first ebike. I have back issues so want a high stack. Currently ride trek slash 8 2021 size large. Riding blue trails at bike park. Hoping to try some blacks but will probably ride around features.
Looking at ( prices in my currency)
Pivot shuttle am base spec...
What do you guys think could be the cause of this grinding noise on my Turbo Levo 2018 bike ? It's coming from inside the motor, only when using pedal assist. No noise when backpedaling, and when the assist is turned off there is zero noise. It starts about 20 minutes into the ride, and from...
I have a dilemma…
In the market for my first emtb and have narrowed it down to these two bikes. I have managed to agree a deal on the Specialized for £3,800 or my local Trek dealer has a Rail 9.8 XT in my size that they will put a frame wrap on it for £5,200.
I had originally decided I...
Hi folks,
I have the adjustable headset cup at -1 on a 2022 alloy.
On the specialized official website, it mentions it is not compatible with the base alloy model.
I think it works just fine... headset seems snug, turning the steerer 90 degrees and rocking back and forth does not show signs...
Hello I changed a belt on my brose s mag(tighten it properly with 0.2nm) and after ~30km under a big load it starts to produce a squeaking noise.
I tried to retighten it couple of times with the same result (using blue past)
Did anyone figure out how solve it?
I bought 2 spare belts, should I...
Hi riders,
Firstly, thanks the great reads over the last few years. Been a while since I was active on any forum, but here goes.
My new eMTB buld rundown: (Incomplete)
2022 S-Works Turbo Levo:
PART:
DESCRIPTION:
FRAME
Frame
S-Works Turbo Levo - Blue Ghost Fade - S3
Dropper Post...
Hi all, does anyone know if it's worth to upgrading the Rockshox 35 Silver 160mm with Fox 36 170mm Grip2 on my Turbo Levo 21, as the Fox is 2020 model. The Fox one is in perfect condition and the price is good. I got an offer for the Fork + Fox Factory dropper post + Race Face Next R carbon...
Hello there! My name is Ovidiu, I'm 21 and I love riding bikes. I currently own a 2020 Specialized Turbo Levo base model which is undergoing a major upgrading process.
The bike was perfectly fine when I bought it and probably still is, but my skills got better and better over time and I...
Hi all.
I know there are lots of posts on this but back is. I've just had the TCU replaced as it was doing the flashing red issue. Its not worse and flashes red twice before turning off.. What do I do now?
Hello
My name is Scott (Moosepilot). New to e-Biking. Still ride my acoustic a lot more. Getting ready for my first race. Mid 40s from the great Pacific Northwest (WA). Bought two Specialized Turbo Levo Comp Alloys.
The new 2023 Levo Carbon is online for £6250:
https://www.balfesbikes.co.uk/bikes/electric-bikes/specialized-turbo-levo-carbon-electric-mountain-bike-2023-in-smoke-black__36143
The 2022 Comp Alloy is available also for £6250...
Hi
Thinking of changing the rear brake on the KSL and wondered if anyone had managed it without dropping the motor and battery? Could you perhaps thread the new outer using the old one to pull it through?
I read about connecting the two outers by using a tandem brake inner because that’s long...
Hi everyone!
I've been riding my brand new S3 turbo levo pro for a bit over 3 weeks / 230kms / 6500m of elevation.
I'm 72kg / 77kg fully kitted, and ride quite aggressivly in the French Alps. I will race the bike at the Mountain Of Hell this year.
I followed specialized suspensions calculator...
Hi all, the reed connector has broken on my speed sensor cable and I'm having diffs trying to source a replacement cable (S166800018 750mm). Spesh stores all say none in stock and no date for new stock. Anyone know where I could get one or even how to fix the connector (wires have snapped at...
Hello!
So after a LBS bricked my battery during a firmware update. I'm forced to either take Specialized offer of $900 replacement battery (which is at cost for a gen 1 504wh battery) or check to see if anyone offers an aftermarket battery.
Does the community know of any aftermarket brands or...
I bought a brand new m-2 700wh battery from a specialized dealer and it had a charge cycle on it already. I’m not sure if this is normal maybe a test charge from the factory? The thing is the 500wh battery that came with my 2021 turbo levo that I just bought didn’t have any charge cycles. Anyone...
I have recently purchased an Evoc tailgate pad for my Nissan Navara.
However I have found that the straps don't fit around my Turbo Levo's down tube, they aren't long enough.
Has anyone else had this issue and found a suitable replacement strap thats long enough for a thick down tube?
Hi,
I just bought a Turbo Levo Pro 2022 (expensive!). I notice that the Tubo Levo's engine is going up to almost 70 ° C (158 ° F). The carbon chassis is hot ... Has anyone observed the same thing? Have read any documentation on this topic? Is this normal? I had a Turbo Levo Hardtail Comp 29, and...
