sram axs
  1. A
    AXS Destroying SRAM Cassettes?
    I have 2023 Ibis Oso with SRAM GX AXS. After six months and less than 400 miles, the shifting went from perfect to impossible-to-adjust gear jumping. This despite a clean chain with less than 0.5% stretch, straight derailleur hanger, and correct b-tension setting at 30% drag. After dropping it...
  2. Not sure the new SRAM Eagle Transmission is for you - What other options are there ?
    SRAM recently released the New Eagle Transmission system. Rumoured and talked about for 4 years and shown in Patents for 6 months now, ridden extensively by Nino Schurter last season, it's finally released into the real world. Originally announced as a modular direct mount derailleur, its...
    Only upgrade done to the bike is the Eagle AXS
  4. B
    Levo Gen 3 TCU LEVO paring with SRAM AXS
    The MasterMind TCU that equips the LEVO PRO can collect information from the SRAM AXS. However, Sensor / Pair ANT / Shifting pairing does not work. Who would have more information on this subject? Thanks . John
  5. A
    Shimano 11 speed Di2 to 12 speed AXS?
    Hi chaps. I have a 2019 pro race decoy. It has Di2. I want to look at changing to 12 speed AXS, anyone on here done this and what should I expect to have to change- free hub and everything?
  6. WheelBased
    Shimano's Wireless Twist-Grip with a Joystick
    Hi Everyone, I wrote an article about a new wireless twist-grip that Shimano are developing. It's configured to change gears, adjust a dropper, and adjust your suspension without taking your hands off the grips. It's a pretty cool idea and supports the assumption that Shimano are coming out...
  7. Wheezy
    The best e-bike I've ridden - Norco Range VLT C1
    I've ridden quite a few bikes in my day having worked for several shops in the SoCal area, some I've had the chance to put some serious time on but man, one day on the Range VLT C1 and I had to buy one. It's 170mm of plush coil goodness. When I first looked at the bike I didn't expect to like...
