speed sensor
  1. W
    Haibike
    Deleted
  2. Jaybee59
    2021 RAIL 9.8 XT SPEED SENSOR WIRE SEVERED
    Well, I screwed up! I unbolted the motor without supporting it properly. It dropped from the frame and snapped the speed sensor (2-wire, black & red) from the amp plug. I've looked at the trouble it takes to buy the plug and re solder. My time is limited and would simply like to replace the...
  3. G
    2020 Giant Trance E+1 speed sensor problem solved
    Problem solved on mine! I started getting the speed sensor problem on my 2020 Trance E+1 a few minutes after a hard whack on a log on the bottom of the bike-motor cover. I thought I was just running out of battery life after a pretty demanding ride. Ended up struggling out of there mostly...
  4. S
    Mission Control Mission Control speed question
    I’ve just had a motor change (1.3) and when I connected the old Mission Control app I noticed that the wheel circumference had gone back to the default. I wanted to change it back to 2000, which means it cuts out at about 27kph instead of 25kph which I find much better as it cuts out less and...
  5. hokkane4
    How to protect your speed sensor
    In Vitus eSommet (most like many other bikes as well), the speed sensor cable is located in danger zone. Earlier this week during the ride, some tree branch went between the spokes hit the sensor cable and pulled the wires out from the sensor. Luckily it happened only 5km from the car and not on...
